Laminate vs solid - how to tell?
Looking at websites for various guitars. The language is confusing to me. How do I tell if the wood is solid or laminate? Some say solid wood top and rosewood B/S. Does that mean the back is not solid?
And... does it matter? My price range is under a grand. |
If it doesn't say solid than assume it is laminate. Very few websites will tell you it's laminate. It's "code" that if it doesn't directly say solid it is laminate. So in your example only the top is solid.
it's the usual marketing language. Mention everything that is good and omit everything that is not. Everything not explicitly stated is implicitly false
Cort AS-E4 Taylor GS Mini Mahogany -- Last edited by bancika; 11-13-2014 at 10:52 AM. |
For the top, the easiest way to tell is by observing the grain pattern at the edge of the sound hole.
The grain pattern on a solid wood guitar follows continuously into the curve of the sound hole, while a laminate does not. But, when shopping online, the rule of thumb is that if it doesn't specifically say it's a solid top or solid back and sides, then it's NOT solid wood. Don't be confused by terms like "Select Spruce"... that's just a fancy way of saying it's laminate. But also, don't feel the need to dismiss a guitar with a laminate back or sides. Many, if not most of them, are actually quite excellent for the money. .
'Common-sewer' of unrefined guitars. Last edited by Buck62; 11-13-2014 at 11:03 AM. |
The 98% answer is that specifying solid top and not sides means laminated sides. Solid is worth more so it's almost always stated if it is. Except for the exceptions, solid wood guitars sound better. It's the top that matters most, however.
I guess it's the exceptions that are the trick, but you have enough budget to get a really nice guitar.
2010 Allison D (German spruce/Honduran mahogany) 2014 Sage Rock "0" (sitka spruce/Honduran mahogany) 2016 Martin CEO-7 (Adi spruce/sipo) 1976 Ovation 1613-4 nylon--spruce top 1963 Guild Mark II nylon--spruce top |
Grain pattern at the edge of the soundhole tells you about the top. For back and sides you'd want to see a grain pattern INSIDE the guitar that matches the grain pattern on the outside. If they're different, it's laminated. And be aware that unless the specs state specifically "solid <whatever wood>" you can assume it is laminated.
That said, depending on how a guitar is built the materials of the back and sides have a very small impact on tone. Some manufacturers use laminated sides almost exclusively ... stronger, easier to shape, almost no negative impact on tone. There are others with golden ears who will disagree. Personally, I prefer all solid woods, but it's really not for any empirical reason ... I've played some fine sounding guitars with laminated b/s. |
I have a Washburn WCG55CE on order. It is all Koa but since it does not say 'solid' - that means it is laminate, right?
Do I / Should I care? |
Imagine it. Your guitar is LAMINATE because it DOESN'T say so....When it comes to revealing to the new consumer what their guitar is made of, manufacturers are dark, shifty and dishonest as any criminal. It is very despicable. I often read every description of every maker...and how they word their adds. Disgusting.
If ever a law was needed to be passed for the protection of consumers...it is a law forcing all guitar manufacturers to reveal in plain words what you, the consumer are paying $1000+ for. |
If it sounds good and feels good to you, then it is good! Your opinion is the only one that matters. .
'Common-sewer' of unrefined guitars. |
Strum the guitar in question. Does it sound like your listening to a guitar while wearing ear muffs? If it does, there is your hpl.
Some Martins Garcia #2 classical Cordoba C10 Luthier Series Tacoma Olympia OB3CE acoustic bass "I don't care what style you want to play. If you want to master good guitar tone, master preparation, attack and release first." ~ Paul Guma |
The one rule you can go by on this topic: a manufacturer will *never* fail to trumpet the fact that any part of the guitar is solid. If top, back, sides are solid, they will say so. The flip side of that, as others have said, is if they don't say it's solid, it's not solid.
As far as whether to care or not, it depends on a ton of different things, many of which are personal to the owner/player. If you love the sound, don't expect much, if any, improvement over time, and got the instrument for a fair and acceptable price, then who cares? You might even find it's less fussy about environmental (humidity) issues, as 90-degree cross-ply construction increases strength.
Craig 1977 Martin M-38 1982 Stelling Staghorn 2013 Larrivée D-40R 2014 Andrew White Eos 1011 (sold) 2016 Pisgah Possum |
Is this really true? We have an old beater that has simply got to be laminate, but looking at the edges of the soundhole it sure looks solid. Do they have a way to mask this?
And I thought, "I've fiddled all night, and lost! You were good, hillbilly ... but you've been bossed." - Mountain Whippoorwill (Or, How Hillbilly Jim Won The Great Fiddler's Prize), Nitty Gritty Dirt Band |
